Old 04-27-2008, 05:03 AM
Silverback51's Avatar
Silverback51 Silverback51 is offline
What you are describing is exactly what mine was doing. After swapping out every piece in the ignition system except the the ignition switch, I found that it was the voltage regulator. It was spiking and causing the MSD box to go crazy.
Disconnect your alternator and see if the mis disappears.
