Old 04-27-2008, 06:43 AM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
If its missing above 3000, something is wrong, you are right to be concerned.
- Check your firing order closely
- Look under the cap for a burned rotor or rotor button in the cap
- Make sure you have the right MSD rev limiter in it if you run one
- If you run vac advance, disconnect it and try it, sometimes a partially broken wire on the module can intermittently break contact when vac advance pulls in
- Make sure all plug wires are separated so they cant cross fire
- Check for gross vacuum leaks
- Check all plug wire resistance
- Check valve train adjustment and/or bent pushrod
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
