04-30-2008, 10:47 AM
UT
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Mike, no pics but I mounted my belts running them over the tops of the seats and through the back cockpit wall and then bolted them to the frame where it kicks up behind the cockpit!
If I remember correctly (4 Years ago) I made an opening (2" Square) in the bottom fiberglass of the upper part of the trunk and drilled through the frame and then ran bolts all the way through! Good solid mounting spot!!
Terry
