J.T.,Since you don't have a top this wont help you much, hoping we could put them on together-oh-well. In the mean time find 24 plastic washers about 1/4" in diameter with an 1/8th" center-give or take. (Black or White are common.) These are going to go between the pins and the body. Get a small bottle of crazy glue or lock tight to put on the threads of the pins-just a drop please. (This will help keep the pins from vibrating loose over time.) An 1/8th" sharp drill bit, a very pointed punch about 4"s long. I use one that looks like a screwdriver handle with an icepick. And of course a top. Is your car striped or unstriped?
DV
