Old 05-01-2008, 12:44 PM
john chesnut john chesnut is offline
I use the diff from the C5 but not the transaxle. Using the Transaxle would have resulted in a very wide transmission tunnel. A machinist friend of mine and I engineered a conversion to allow the use of the diff with a driveshaft. The rear cradle has essentially an "engine plate" welded in that the trans tunnel is welded to. The diff bolts into this plate. The tunnel becomes a large torque arm for the chassis. Virtually any engine and trans combo can be used as I have a bolt in tranny mount that can be placed in the proper position.
To make the C5 parts work required new chrome molly axles which are 1 7/8 inches narrower, the diff conversion, and a new steering rack as the front track is substantially narrower. 315 front tires and 345 rear tires will fit with out modifing the body. 295s are shown in the rear, 275s on the front, both on 18 inch rims.
The over the top headers allows for long and wide footboxes. It is 47 inches from the back of the cockpit to the pedal faces with 15 1/2 inch width at the pedals. The cockpit takes up to a 20inch wide seat.
The rolling assembly as shown weighs 1488 lbs (Without me!)
Thanks for the question. John
