Old 05-02-2008, 12:11 AM
stephen low's Avatar
stephen low stephen low is offline
Gregg
Like Al I've just gone through engineer early December but I did use Bernie. I had standard cats only in the exhaust system and of some age 60K odd old but I too essentially had zero emissions impacts. Bernie does this test as part of his assessment!
Stick to your line with Bernie they are standard cats. If your challenged you have to prove or change the system, if they fail they were "old" cats to your knowledge and you still have to change. Either way it is worth a try with what you have.
Al's right in that Bernie's focus was emissions from what is supposed to be a standard car set up and lens ADR markings.
What have you got to lose?
Steve
slowy
