  #29 (permalink)
Old 05-03-2008, 01:44 PM
Rick Parker's Avatar
Are you using the pre-made (from MSD) dual wire cable (violet/green & orange/black)with the plastic connector ends on it? Or did you rewire the MSD box to the distributor? If you did the later you may have the distributor out of phase. Check those 2 wires very carefully. The violet stripeed wire in the cable does NOT connect to the Violet striped wire from the distributor.
Rick
