Old 05-05-2008, 06:59 AM
Three Peaks Three Peaks is offline
Eccentric shouldn't move at all. It should be indexed with the cam pin and bolted tight with the cam bolt and washer. Sounds like something came loose. Probably a good time to pull the timing cover to check it out before you lose your cam timing gear or drop a bolt or pin into the timing chain and take out even more parts.
Bob
