Some of the later OEM (approx 79-82) were 2 piece allowing the outer diameter shell to rotate for less friction. However you may be on to something if the one you have is one piece, it should be clamped tightly to the cam gear. Possibly the camshaft dowel pin is not protruding into the eccentric. Three Peaks is giving you some good advice.
Rick
