Old 05-05-2008, 01:35 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Take the battery out and have a load test done on it. Fully charged is not always FULLY charged...if you have a bad cell..replace the battery and your problems are over...If all else checks out ok, tight clean cables on the battery. Tights clean chassis ground...Correct output from your alternator to charge the battery, then look into the solenoid...
