Thread: Trans removal
Old 05-09-2008, 06:08 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Default Trans removal
Not sure this is the place or transmission would be better for this. Not all are of us lucky to have a lift in their garage so transmission work can be a real pain. One way I have found to make life easier is to use long bolts to be able to slide the trans back on without taking it out.
Example, say I want to work on the throw out bearing. I start by removing the bolts of the trans from the bellhounsing and replacing them with the correct thread 10-12" cap bolts. Tighten these until they bottom as you want as much aligment as possible later. While still sporting the rear of the trans, after you have disconnected the drive shaft, slide the trans out on the bolts. Keep the rear of the trans supported and you can now slide the trans backwards. Do your repair and then slide the trans forward, the bolts act as an aligment tool.
Also, if you are placing the trans up to the bellhousing after it has been completely removed, I use 5-6" bolts with the heads cut off, only hand tightened into the bellhousing and slip the ears of the trans on to the bolts. It really makes woking with the trans a lot easier. Especially, if you are doing it on you back. Just a thought.
bkozlow
