Old 05-09-2008, 08:50 AM
Jimi G's Avatar
Jimi G Jimi G is offline
bigrob, I have seen driveshaft yokes crack and cause oil to leak out of the yoke itself, although it is rare. The first thing I would do is drop the driveshaft and inspect the rear of the yoke for a crack and also check out the surface on the yoke that the seal rides against. If the yoke has a groove in it this will also cause a leak and while you are there I would look at the rear seal a little closer as well as the speedo connections. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
