Old 05-09-2008, 05:09 PM
Barry_R Barry_R is offline
We use, stock, and recommend the Erson setup quite often for moderate builds. I have run them with up to 600 lb springs with no failures to date. There are a couple things to pay attention to.
First is that you need to use the AN washers supplied by Erson even if you choose to run studs for mounting - a standard large diameter washer will hit the rockers.
Second is that you will need to mark for and grind/machine reliefs on the bottom of the mounting stantions if you are using head studs instead of bolts.
You will want to restrict oiling (+/- .090) since the needle bearing design will "bleed" more than a traditional FE bushing style rocker.
Make sure to lube the roller tip for initial startup. Spray will take care of it from then on - but the tips are not directly lubed.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
