Old 05-10-2008, 03:11 PM
MCOULTER MCOULTER is offline
Originally Posted by Velox View Post
You mean like this
Just my opinion FWIW but I would not attach the amp wiring to the Smiths voltmeter. All the accessory current flows through those wires on the ammeter from the battery source and the fuse assembly, check Blas's SPF wiring diagram for review. Those large ammeter wires need to the carefully and thoroughly soldered together and very securely shrink tubing isolated from anything else and zip tied carefully in a secure safe place. The tiny terminal on the voltmeter is not sufficient purchase for such heaving wiring to be positioned and connected there. Attach a "key-on" 12v + source to the positive side of the voltmeter, such as the wire that goes to your lighter or similar, other side of the voltmeter to ground. That's how I did it, works fine
Odd thing, I disconnected the red wire to my lighter and placed it on the positive terminal on the voltmeter. Everything seems to work fine except my windshield wipers run continuously. I was just going to disconnect the windshield wipers. Any other ideas?
