Old 05-10-2008, 10:15 PM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
Default slipping clutch
To check your free play on your throw out bearing you need to release the spring pulling the fork back. Then you will be able to jiggle the arm an see if you have free play. Thats the way I check mine, because that pull back spring is strong.
