Old 05-11-2008, 05:52 AM
Default They are finding HP with different locations
Barry R. Barry I have the same setup with the dove converted manifold for FI. They are finding out that the injector location can be worth up to 28HP. The angle down the port is also important. The info not released is which injectors are being used and what the spray nozzles are. The angle on my injectors is 78degrees. If you have the room and can get into the 40 degree range they are finding more power. I also think you have a little supercharging of the port with the fuel being forced out of the injector at 45 psi at a better angle than the one we are running. Rick L.
