Old 05-12-2008, 03:16 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Originally Posted by wetdog View Post
I did it just like DV says works great , electroic speedos need dedicated grounds , so do msd boxes , and the starter solinoid, thats three already . Also if running batt in trunk neg lead all the way up to the block. Body goes on this week wish me luck. WD
Nice to know someone knows to have dedicated grounds for some electronics!
You dont want to just pile on the grounds on one lug. This can cause a feed back to sensitive equipment, even radios.
I am starting a entirely new manual on DVD for the CR's Cobra. when it will be done I don't know but after 25 plus years it's past due. It will cover everything I know and many hints from other builders/home owners. Hopefully it will be absolutely detailed, clear and precise!
David, feel free to jump in anytime-thank you.
Wetdog, paper and pen in hand, give me a call and we will go through the entire mounting of the body- take every "self-tapping screw that came with the kit and throw them away! Couple of 1/4x10x20 taps, a couple of proper drills and a whole box of 10x24 "FLANGE" screws, (AND flange nuts) in various lenghts from 1/4" to 3/4" inch in length! I'm ready when you are!
DV
