Old 05-16-2008, 04:40 AM
patrickt patrickt is offline
Originally Posted by olddog View Post
My dad has a bank beside his house that I would guess is 20 degrees (drops 8 feet in 24 feet). I'm thinking of backing over the bank and pulling the cap. Should that do the trick?
It very well might. But, make sure that you don't move all your oil off your pick up in the pan in an effort to tilt your car to get the air bubble out (meaning, keep an eye on your oil pressure gauge). In Cobras, air bubbles will usually be in either the manifold or the non-hose side of the radiator. Cracking a fitting in the manifold will usually take care of that pocket, and a burp fitting like you see on my radiator below will take care of any radiator air. Try your "back over the bank" trick, but be careful.
