  #22 (permalink)
Old 05-18-2008, 10:34 PM
ng8264723 ng8264723 is offline
Cobra Make, Engine: Kirkham 592
Well nothing like objective numbers. Here is the breakdown of the options on that car. Add $15,000 for the suspension upgrade (original specs), $15,000 for the engine, $2,000 for the tranny and bell. You are over $100,000. I'm surprised since you just bought a Kirkham that you didn't think it would be over $100,000 for this. This car proves what I'ver been saying you don't get your cash back for some of these expensive options.
chris
427 KMS/SC Options
Interactive Price Worksheet
Please select your options and the total price will be shown at the bottom of the page. Total includes the $39,995 base price.
Click on the name of the option for more information
Part #
Aluminum Body
• • • aluminum body finish: filed -
00002 aluminum body finish: brushed 7,999
00022 aluminum body finish: polished 13,900
00003 main stripes (w/ brushed or polished body only) 1,995
00004 pit stripes on fender (w/ brushed or polished body only) 395
00009 hood scoop, 427, aluminum (replaces fiberglass) 295
• • • hard top, Le Mans style, aluminum 15,000
Frame
• • • frame: steel, powder coated -
00404 frame: stainless 4,995
• • • roll bar: steel, powder coated -
00092 roll bar: stainless 595
00296 aluminum frames for hood, trunk, and doors (lightweight) 995
Body Hardware
• • • wiper system (included) -
00297 jack hooks, lightweight aluminum, set of 4 95
00291 brake scoops, fiberglass, set of 2 245
00007 heat shield for foot boxes, polished stainless 495
00008 ferrules, door, set of 8 95
00013 fuel tank straps, billet 95
00405 fuel tank, 42 gallon, (upgrade from 30 gallon) only available on 427 models. 2,250
• • • no wheel well foam -
00005 wheel well foam, uninstalled 95
00476 wheel well foam, installed 595
Interior
00161 carpet, nylon, not installed -
00477 carpet, nylon, installed 695
00016 carpet, wool, not installed 795
00478 carpet, wool, installed 1490
00303 seat tracks, adjustable, billet aluminum 695
00019 sun visors 195
00020 wind wings 195
00087 pedal assembly: brake & clutch, billet aluminum 95
00021 powder coat rear bulkhead and wheel wells 495
• • • steering wheel, wood, 15" -
00307 steering wheel, leather wrapped, 15" -
00410 steering wheel, wood, 16" (upgrade from 15") 395
00023 leather covered dash 395
00024 seat belt, upgrade to 6 point harness (requires roll bar) 125
00025 halon fire suppression system 525
00311 fresh air ventillation system, driver's footbox 495
00312 fresh air ventillation system, passenger's footbox 495
00402 dropped footbox, (for tall drivers) 1,195
Electrical
• • • wiring harness w/ relays and switches (included) -
00027 battery, sealed, with mounting tray 200
00028 battery cutoff switch (recommended) 95
• • • gauges, full set (included) -
Engine Compartment
00053 radiator tube set (includes tubes, hoses & clamps) 295
00287 Coolant Tank: (Billet Aluminum) 500
00078 oil cooler (heat exchange unit only) 195
00052 oil cooler, complete assembly 895
00031 motor mounts, FE block, set of 2 195
00032 motor mounts, 289, 302 or 351W block, set of 2 295
00033 distributer hold down, billet aluminum, FE 25
00280 alternator bracket, billet aluminum, FE 95
00038 throttle spring & billet bracket 25
00039 air cleaner cover, stainless 125
00040 air cleaner element, K&N E-1025 60
00041 cold air box, (turkey pan) 425
00042 fuel filter and fittings 195
00047 intake manifold breather, billet aluminum 50
00046 oil vapor separator tank 295
00414 stainless steering shaft and u-joints (upgrade) 125
• • • no side pipes -
00050 side pipes, complete w/ header tubes, steel, 427 - Not installed, requires welding & fitting 1995
00555 side pipes, stainless, complete w/ header tubes, 427 2995
00569 side pipes, stainless, polished, complete w/ header tubes, 427 3995
Transmission
00423 transmission mounts, Tremec, must be welded to frame 395
00056 mount & bracket, for toploader 95
00502 shift lever handle, for Tremec 295
00054 shift lever handle, for toploader 195
00055 shift linkage, for toploader, heim jointed 295
00058 shift knob 25
Drivetrain
00061 Kirkham differential, aluminum w/ mounts 5,000
00063 adapter kit to mount cast-iron Jaguar differential (instead of Kirkham diff) 395
00064 breather hose, differential 95
00066 driveshaft 325
00067 half shafts, set of 2 895
00068 driveshaft safety loop (recommended) 95
Suspension
• • • shocks & springs, set of 4 (included) -
00069 shocks, Penske w/ Hyperco springs, non-adjustable, set of 4 495
00070 shocks, Penske w/ Hyperco springs, adjustable, set of 4 2,995
• • • suspension, original style, (replaces standard billet suspension) 15,995
Brakes
• • • brakes, vented disk, standard size -
00403 rotors and calipers, front, 1.250 inch thick (upgrade from .810) 295
00011 reservoirs, brake and clutch, billet (upgrade) 95
Wheels & Tires
• • • tires, 245/60-15 front and 275/60-15 rear w/ wheels (included) -
00409 tires, Goodyear large letter, set of 4 w/ wheels, (upgrade) 995
• • • tires, Avon, V rated set of 4 w/ wheels, (upgrade) 1,495
Labor
• • • mount body on frame (included) -
00071 assemble to complete roller (not including items listed below, installation of carpet or wheel well foam) 4,995
00072 alignment, preliminary (final alignment requires engine & transmission installation 295
00051 labor, cut outs for side pipes 500
00060 labor, fill and bleed brake system 125
00586 export fee for all cars shipped outside the US. 3000
Price with selected options: $ 73984
Order
After choosing your options fill out the following form to submit your order. Use the comments section for any special instructions. Contact Kirkham Motorsports at 801.377.8224 for a KMS order number.
Name
Email Address
Phone Number
Comments:
KM will do its best to anticipate demand, but availability of all parts at all times is not guaranteed. KM reserves the right to substitute parts of equal or greater value and similar functionality without notice. Any of the prices are subject to change without notice. In case of an error, we reserve the right to correct problems. No prices are final until received with a handwritten signature directly from an authorized person from Kirkham Motorsports.
