Old 05-23-2008, 07:12 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by FatBoy View Post
My clutch slave cylinder is leaking fluid. It was supplied by Southern Automotive, but I haven't been able to get hold of anyone there all week to find out if a repair kit is available.
It is a 1" bore cylinder with "S-134" cast into the side. Does anyone know what replacement seal I need?
Thank you.
Paul
Sounds like you over extended your slave.
When you replace/repair it you should check and see if a clutch pedal stop is in order.
