Old 05-25-2008, 07:58 AM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
It does seem odd, but that's exactly what it is. Otherwise you'd need a different distributor and oil pump.
It does help in torsional strength over the length of the shaft, and theoretically the smooth surface of the majority of the shaft "could" be less vulnerable to stress cracks but that part is really reaching.
I personally have never broken a Ford oil pump drive on anything that wasnt caused by some other failure. However, I do also run an oversized one from Doug Garifo on my 489. The 427 before it and the 390 in my F-100, as well as most any other one I build, I just use a good Melling driveshaft though
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
