Thread: Ford Waterpump.
Old 05-27-2008, 01:05 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Exclamation Wrong way.
Originally Posted by Rick Parker View Post
1 barb is designed to have a curved hose attached to it and to the nipple on the thermostat housing, to provide a coolant bypass, while allowing an even warmup of the engine. The other barb is drilled, tapped and plugged with a 1/4" tapered pipe plug if no heater is being used. If a heater IS used, one of the heater hoses attach to it, with the other hose going to a 90 degree barb coming from the intake manifold. Water exits both barbs.
Wrong flow direction Rick, Water enters both barbs. Water to heater exits intake manifold to heater & returns by lower barb on pump. Upper barb on pump connects to thermostat by-pass on t/stat housing- flow being from T/stat to pump.
Jac Mac
