Old 05-29-2008, 11:45 PM
COBRANIP COBRANIP is offline
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
Harbour Freight sells the engine stethoscope pretty cheap and it works pretty good.
Also, any metal rod or bar will transmit a surprising amount of noise (touch one end to the engine where you suspect the problem and hold your ear close to the other end). Try a breaking bar or some rebar. Good luck.
