Thread: seat belts
Old 05-30-2008, 07:26 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Robert,
Didn't mean to leave you hangin'. Some glitches here.......On the rear frame member just about where the large threaded rod (spring aduster goes) does it have two small tabs welded in? One on each side. The tabs will have about a 1/2" hole drilled in them. If this is the case You should have two holes on each side of the car, at the rear of where the seats bolt in and both of these holes will have nuts welded in from the back side. Nuts are not visible from the top side. If these are there this is where the lap belts will bolt in, the "Y" harness will then bolt into the top bracket.
If this is not the case feel free to call me and I can tell you how I install the lap belts.- (231) 869-4608. Any time from 7am to 11PM EST- 7 days a week.
Let me know please.
DV
