Old 05-31-2008, 04:47 AM
stephen low's Avatar
stephen low stephen low is offline
Thumbs up Cannister layout picture
Hogster
Got to the car this morning and took the following picture -
Attachment 14085
This shows my cannister located above and behind the rear wheel in the top inside of the driver's side wheel arch.
Top line is the purge line to atmosphere and just runs around the rear of the arch to the outer side of the wheel well. The other line is blanked off.
The lower connector line leading to the clear hose is then connected high up on the fuel filling neck. The other line leads around to the engine vapour line through the purge solenoid.
You need to think about how you mount the solenoid as when mine turned on you got this strange high frequency rattle. Until I figured it out I was paranoid the engine was having a failure.
Hope this helps.
slowy
