Old 06-02-2008, 08:37 AM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Originally Posted by MrMagoo View Post
The heat in my fuel lines coming out of the fuel pump is really hot, almost boiling. I am thinking that my Holley problem is really a heat related issue. I just bought a carb heat shield and some other thermal protective stuff from summit, and I am going to try to get that problem resolved before I attempt the Holley again.
If the gas WAS boiling coming out of the pump, you would have problem with any carb, including the Edel-brick.
Sounds like you "should" reroute the gas line or add insulation or a shield to keep heat away from the gas line. It cannot hurt.
You need a carb spacer. The hot non-boiling gas from the pump is boiling in the Holley float bowls due to the radiant heat from the intake manifold. Use metal or phenolic. I would not recommend wood. There is enough stuff that could burn in a car without adding wood. I've never heard of a wood carb spacer.
Summit and Jeg's have a nice variety of carb spacers. As I mentioned previously, measure air cleaner to hood clearance before installing spacer.
Warren
