Old 06-04-2008, 05:29 PM
GlynMeek's Avatar
GlynMeek GlynMeek is offline
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Mike...go check out the Lonestar forum on the Wilwood slave cylinders for some potential issues on how the pistin rod comes unscrewed from the piston and can cause failures.
http://www.lonestarclassics.com/__LS...hp?p=8116#8116
This may NOT apply to your configuration as it seems most of the issues are with the T56 tranny, but it is a simple step NOW if you disassemble and then reassemble with Loctite BEFORE you install it. The Lonestar forum postings are fairly detailed!
Good luck
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
