Thread: Ford rear end
Old 06-05-2008, 07:29 PM
Philm's Avatar
Philm Philm is offline
Default Getting there
HI Alffie,
I have machined the bosses for the rear plate and will bore the rear cover and weld them in on the week end.
I have done lots of measurements and I think everything is ok, may have to clearance a bit of the cradle that holds the diff.
The front mount is a bit simpler I may be able to use the existing mount.
The plan is to have the rear mount done then pull the old one out and work the front mount.
Then assemble the diff, order axles then we are away.
IMG]http://i158.photobucket.com/albums/t84/whybejoso/IMG_0730.jpg[/IMG]
Phil
Last edited by Philm; 06-05-2008 at 07:30 PM.. Reason: spelling for the anal retentive
