  #23 (permalink)
Old 06-08-2008, 02:27 AM
Plums Plums is offline
Originally Posted by sideshow View Post
looking thru my tunes on my hp tuners most of the time the std ls1 tunes have bugger all timing as they have 2 timing maps
std they use the low octane map
They do have 2 timing maps, a High Octane table and a Low Octane table. Standard they don't use the Low Octane table. These names are a bit misleading.
They will always run in the High Octane table (regardless of the type of fuel used), until you get knock (pinging). When it pings, it will interpolate a timing value (based on the knock learn factor) somewhere between the High Octane table and the Low Octane tables value. If the knock events persist, (due to a bad batch of fuel, OR a tuner adding too much timing) it will basically "live" in the Low Octane table.
