Old 06-08-2008, 06:06 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Default Mounting rear QA-1 and PROS shocks to CR frame & axle
This eliminates all extra bracing etc. Simple bolt in procedure with the proper parts;
1) Four shock mounts needed. Any auto parts store carry's them; NAPA,CAR QUEST, AUTOZONE etc.,
Sorry for being so fuzzy-can't find my tripod!
Then knock out all OEM factory bushings. (I use a socket and a big hammer!)
Mount one shock adapter in the designated loation on the frame itself:
Install one shock mount in the OEM hole on the axle bracket
I then apply "Anti-seize" to upper and lower washer and about half way up the threads of the shock;
Mount the shocks!-Perfect fit- extremely strong and no clearance problems!!
Just to eliminate any confusion, take the bushings that come with the shock mount kits and throw them in a drawer someplace-not needed-not used!
Any questions?
DV
