Old 06-08-2008, 08:20 AM
tcrist tcrist is offline
DV,
That looks great but that would not work on the Pro-Shocks that I received from CRII. My Pro-Shocks came with a thick tapered aluminum spacer that I had to use or the shock would hit the brackets on the frame and on the rearend. Even with the taper on the spacer I still had to put an 1/8" washer between the spacer and the shock to clear the spacer. Now that is probably because CRII send me shocks that had spherical bearings instead of rubber bushings but I would have still needed the tappered spacers anyway (I think). I'll see if I have any pictures and post them of the shock mounting.
I know, It's dirty
Terry
