Terry,
What you are looking at ARE pro shocks- without the spaces that came from Don!
The shock mounting kits make up for them!
Ahh, I just noticed your PRS had the sperical bearings I think in that case you will use the bushings that some with the shock mounting kits. Not real sure on that one but they should work this way. Maybe....a small washer on the front side of the bushing then the shock and if needed another bushing, small washer and bolt up.
DV
