Old 06-08-2008, 08:46 AM
tcrist tcrist is offline
DV,
Ok, But the shock mount kit that you have bolted onto the bracket looks like it spaces the shock out maybe 1/2" - 3/4". I needed the spacer which is approx. 2" thick to move the shock out far enough for the spring and the adjuster to clear the bracket on the rearend and the upper frame bracket. I did buy the shock bolt kit that Don said to buy but it would not space the shocks out far enough. Could this be because the shocks that he send me has the spherical bearings on the ends instead of the rubber bushings? I like the way that yours sets better because it moves the shock closer to the brackets instead of out over 2". Better for the load that way.
In the one picture with the tape and the 11/16 and 1" dimensions written on them. Did you drill a new hole for the shock bolt?
Terry
