Old 09-29-2001, 10:45 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Thanks Bob,
The factory wiring on this Lucas 3 wire motor had the ground wire going through the park switch. Every revolution of the motor caused a dead short and a popped fuse. The wiper switch is hot in off and activates the park function. I put a diode in the circuit to keep it from feeding back through the ignition. Shortly after installation, the park switch broke so I had to disconnect it.
Am working on a park switch that uses a standard industrial limit switch to park the blades.
