Old 06-09-2008, 04:18 AM
sideshow sideshow is offline
what year is the 302
just make sur eit has no security
if its around 94 95 96 and a mustang 5 lt u should be fine
injecotrs is a good thing to do
clean throttle body with kero ir something soft
do not use carby clean or anyhting harsh as fords have a protective layer on butterfly
and if u use somehting harsh i can remove this layer and it can cause idle probs
change spark plugs
check coils and leads
im sure thats the engine with 2 coils on front on engine each coils has 4 posts
last one of them i wired up it had a broken coil plug which happened dring transport
this is very common cause ford stuck them in the dumbest spot
my website
www.sideshowsperformancewiring.com.au
