Old 06-09-2008, 04:42 AM
sideshow sideshow is offline
best spot is look under the dash where u fit the wiper motor
then drill a hole thru there and u can run the wiring to the frnt end headlights fans etc
this way its kept under the lip in the enigne bay
or u can do like ben suggested we do on his car is drill a second hole thru to the wheel area so the wiring is totally hidden then run it to fron then under the radiator support frame work
there is afew spots for wiring to engine
u can also go thru hol enext to wiper motor then run it to wards drivers side along firewall
or u can drill hole in gbox tunnel and run engine wiring along top of gbox and to enigne
just go over how your loom is and see where best spots are
look at is a s a whole not as one loom at a time and try to picture where evrhting els eis in engine bay cause if u make a mistake then u have to redrill holes or relocate things
doesnt yr loom have a plug half way like most ford v8 looms
ford looms have bloody plugs everywhere
they have ecu section and then engine section then they have gbox section
pain in the butt and bloody expensive if u need to buy them new
my website
www.sideshowsperformancewiring.com.au
