Radiators
Mick:
I thought Jeff put a fluidyne in his car and angled like the originals... I want to get something that will fit in the stock position but give me more cooing. My radiator is ok, but I blew off the top hose coming back from a ride on Sunday. Fortunately only a few blocks from my house. The hose just came off the water inlet . I don't know if it vibrated loose or the pressure pushed it off as it was registering about 212 degrees at the light before I started to roll again. The car runs hot about 190-195 degrees, which I'm told is normal for a BB. I', running a 16 lb cap and a 180 degree thermostat which id drilled out as well. I have twin pusher fans in the front and one puller in the normal rear position. perhaps a better puller fan may help? Any ideas. I'll check out Howe and PRC today. Thanks guys.....
Ralph
