Old 06-10-2008, 09:20 AM
TMark390 TMark390 is offline
Cobra Make, Engine: Hurricane HM2006 FE & Toploader
Have you looked at the possibility that the upper joint failed first causing the break at the lower joint and tie rod as wheel snaped back? Just a thought, but if the lower joint was tight and correct taper it should not have sheared like that. The start of the threads should be higher on the stud, so the tapered sholder is what is contacting the spindle hole.
