Thread: Boss 331
Old 06-10-2008, 09:46 AM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Originally Posted by DAVID GAGNARD View Post
I have the new BOSS 302 block in m racecar, it is a 331 stroker also...... Block is VERY meaty and everything on it is heavy duty and machined, a true work of art.................but,beware, they give you very little info when you buy the block and calling the Ford Motorsports Tech Line is a joke!!!!!!!!!!!!! They give you absolutley NO techincal advise on head bolts/studs, head gasket or anything else you ask them.....
And they ARE having "Some Issue's" with the 4.125 bored blocks, that's according to what the tech guy let slip..........
David
So what is the recommended head gaskets, studs/bolts, etc? I also believe the screw in soft plugs are sold separately from the block.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
