Old 06-10-2008, 12:09 PM
computerworks's Avatar
computerworks computerworks is offline
Larry - good luck.
Took me quite a while to find the original one... there are several variants that have the same "positions," but with different terminal connections. (screw-type vs.push-on, I believe)
If you are doing your own wiring teminations...either would work.
I think the one that has the "wrong" type (wrong in the sense of an original harness, but electrically correct) was used in the early Jag as well.
