Old 06-11-2008, 09:09 AM
Default Good luck with the car and motor
Priobe Good luck with the car and motor. Don't get cranky but what did they use for the adjustments of the webers? A/F meter? Where all the EGT readings within 100f of each other? Not sure what the temp is in your state but would like to hear about how the car is running with a 30-40 degree drop in air temp. I hope you have good filters and screens to keep the junk out of the motor. Again good luck with the car Rick L. Ps You may be setting a new front than running a larger cam with webers is doable under the right conditions.
