Old 06-11-2008, 09:31 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Originally Posted by calbullet
"...what system did you install? and can you take some pic's of the nozzle placement in you car..."
Sure, Mel...gimme a day, or so, on the pictures, but meanwhile...
I installed a Safecraft model RS fire supression system in #770...it came with sufficient hardware to install one discharge nozzle, and the actuator T-handle, etc. After reviewing my installation plan, I purchased additional tubing, compression and T-fittings from Safecraft. They're easy to deal with and very knowledgable about their products. Here's a link...Safecraft Model RS 5 lb system
I installed a T-connector under the transmission tunnel and ran a line straight up the inside of the tunnel. Then, I mounted one nozzle in the cockpit on the left leg of the scuttle brace, just to the right of my right knee....about 4-5 inches up the brace before it disappears under the dash. The other leg off that T-connector goes into the engine bay, and up to the firewall, where I mounted another T-connector. From both legs of that T-connector, I ran tubing around both sides of the engine bay, using the backside of the fenderwells to mount the tubing. Finally, I gently bent the aluminum tubing up above the valve covers and mounted a nozzle on each side of the engine with the outlets pointed directly at the carburetor, since I figure that's the most likely place a fire will start... I'll snap some photos and post them...
Mel...are your a SCOF member? If so, I have a complete detailed write-up of my Safecraft fire suppression system install posted there on the Technical Bulletin area of the website...full write up, pictures, etc.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
