Old 06-11-2008, 04:06 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Kawika,
The holes are for 3/8's bolts. Do not use a cheap tap. All you need is to break a tap off in the hole.
Going after Don, Buddy I wish I could tell/ask to hang on, but I just don't know. As I've told the other guys, write a certified letter to Don, if you haven't, and if nothing happens then it is time to go the legal routes. I'm not a lawyer but I did spend last night at home! I'm sure they will charge you $200.00 bucks or so and tell you the same thing.
Cpteddie; Ed, not to seize !!!!!!! Tapped and John and I are installing, welding your doors in as we speak! Might even get to the hood if the doors don't take to long!
DV
