Old 06-12-2008, 02:13 PM
RAO-3's Avatar
RAO-3 RAO-3 is offline
Cobra Make, Engine: ERA #775
Sounds good to me -- dual four barrels would be for looks only on that mill; you'd get the same performance from a single (and a single is easier to adjust). Regarding cams, I went with a solid, flat tappet cam. There's some risk in doing that, but a small upside too as far as I'm concerned. There's no downside to one provided you can get by the first 1000 miles without eating a lobe. If you're thinking solid flat, then you'll want to do some searching on the break-in and zinc issue. If you're thinking solid roller, then you'll want to do some searching on the solid roller compatibility with FE issue. If you're thinking hydraulic flat or hydraulic roller then you can pretty much stop thinking and just do it -- it'll work out fine. Both Tremec and Richmond are fine transmissions, but you must pay attention to how the gear ratios, rear end ratio, and your torque curve all come together. There is a benefit to having a first gear that will allow you to go slow. Keep that in mind when you're spec'ing out your gears.
My thought on the duals was for looks and not really for performance; I may end up going with the single after talking to the engine guy. I'm also leaning towards the hydraulic for ease in maintenance. Who knows, this may all change after I hear from Peter and the engine guy, but at the same time value the opinions of those on this board greatly, since you've been down this "road" before. Kramer, I had considered the 427 SO (isn't that what everyone wants?), but it seems that for what I'm looking for, it would be more $$$ than is really necessary. And I didn't want to get the 390 since that wasn't in there originally.
Good thoughts on the gears, hadn't really thought that through yet.
Ray
