Old 06-13-2008, 05:46 PM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Thanks guys. yes it was the thermal fan switch i was talking about. I did change the relay and that wasn,t the problem. I did find the fan switch at a local imports parts supplier. Appently for a VW. If you look at the hex of the switch you will find engraved very small 92 and 87 signifying the kick on and off temp range of the fans in celcius, thats what the factory puts in and thats the range that i re-instaled with. Just finished removing and installing. Used 29mm socket and U joint with extention on 1/2 inch drive extending just bellow the crossbrase were the the chassi # stamped. It was a tight fit but do-able without droping the rad.
