Thread: Ls7/gen 4
Old 06-14-2008, 08:18 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
There is some good aftermarket dry sump setups for the LS series motors. This setup from ARE is what the Motec Daytona Coupes run. Probably a better system than the LS7 setup.
ARE Dry Sump
They can be setup with an external scavenge pump with 1,2,3 or 4 scavenging feeds/stages to pull oil from the sump and one pressure pump to feed the motor.
The Daytonas use the external scavenge pump and retain the stock factory gyrotor pressure pump. This is probably the ideal setup for the street/track.
Mike Murphy
Melbourne Australia
