Thread: 48 IDF jetting.
Old 06-15-2008, 01:35 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Caprimaniac View Post
OK. I found my book of notes on everything...
Jetting is:
Main venturi: 38
(Aux. venturi maybe 4.5 - no notes on this, silly me)
Emulsion tube: F11
Air correction: 190
Main jet: 140
Accel. jet: 50
Idle jet: 45
(Float valve: ?, no notes on this, either)
This combination has worked well in my 302 which freely spun up to 7500 (until block cracked). Driveability was OK, although there was a flat spot down low- maybe camwise, since it's a high-lift high- rev unit.
This combination was NOT run on a dyno, unfortunately.
Hope for input on the matter: putting these carbs on the 347.
Anyone have the jetting for whoever it was who got 595? Hp from his 347 stroker @ 7200 (?) ???? (Now I cannot remember what forum I saw this persons postings....)
Now- I'll go to my workshop in an hour- checking aux. venturi size as a start....
Regards
Rune
Rune,
My combo is on a 304 Holden V8.
Choke 38, aux 4.5, main 150, air 180, F2 emulsion tube, 50 idle , 50 pump, 50 pump bleed.
Engine 10.5:1, 4.030 bore, 3.025 stroke, 242@.050 solid cam .576 valve lift.
Gary
