Old 06-15-2008, 06:56 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by RAO-3 View Post
Rick, as I understand it, the emissions requirements are determined by the year of the block, so to stay away from the catalytic converters, am I not stuck with a 428 FE iron block? My thought, given the emissions situation was the 428 block with aluminum heads, the street cam with hydraulic lifters and twin holleys. You don't like the sidepipes? HP wise, I was hoping for something like say 450hp or thereabouts. Not looking for rough idle, no racing, just driving, cruising and parking. Also was thinking the twin holleys to be closer to what was on the cobra 428's, rather than performance.
Patrickt, from everything I've read on this board, the outboard rear seems to be the way to go so I was going to go with that.
Ray
Ray-
That is correct. Year of the block will determine what emissions equipment the engine must have on it. If you get yourself a 60s dated coded block, you will only need a pcv valve.
Replica is not a dirty word.
