Old 06-15-2008, 07:39 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Default Whos are these? :)
Dave,
Painted black but if that is not your choice you can simply paint over them. IF they do not line up perfectly with your doors holes (Ed's didn't) just grind the holes in the door as little as possible, do not thry to move the newly tapped holes.
If I may, when you put the hinges together run a drill the exact same size as the tube for the hinge through the tube/barrel. Sometimes the heat from welding will warp them a little. Then put the brass bushings in tight. Now when you install the hinge to the "U" brackets, start at the top of the "T", not at the bottome where the holes for the pins are. Being as carefull as possible you will probably have to use a hammer to get them started over the bushings but you do not want to beat up the bushings. Now is the aggravating part, put your pins in being carefull that now the holes are lined up exactly. Piece of cake . Beat your caps on one side at a time on the pins and you're ready to go-no wobble in the doors!
DV- They will be in the mail Monday morning since it is Sunday now.
One more thing the bolts I have included are called "flange" bolts, no washer, or lock washers needed. Suggest just past finger tight until the doors are lined up. These bolts will grab like you wont believe!
