Thread: Wire Separators
Old 06-15-2008, 08:38 AM
FWB's Avatar
FWB FWB is offline
Default separators
Originally Posted by eddytheb View Post
I'm having a problem and I'm hoping club members can help me with.
I have FE engine with Cobra LeMans valve covers with a flange for mounting a 4 wire separator. Unfortunately, I have tried Ford dealers , on-line parts, etc. but have not been able to find the wire separators anywhere. Even a on-line sites (such as Jegs) who have the actual valve covers were unable to tell me where to find the weparators. The separator is a three separted finger part which slips over the flange to hold the spark plug wires over the valve covers.
Would appreciate any help locating a vendor for the parts. A part number would be most helpful.
Thanks for your help.
yes they are avail as the others said, the problem i ran into is they are sized
for small wire diameter, the aftermarket wires are too thick to fit into them.
i used msd's separator and tapped the plastic separator for a #6 screw
on most valve cover tangs there are 2 holes to run the screws thru. i used
short 6-32 stainless shcs ran them in from the carb side so you dont see them.
